OP
OP
DougalsMD
Interesting it does look handle like…I thought that just might be a hinge and the entire rear of the vehicle would swing open like a Defender?
OP
OP
Cysco
RE: the rear door.
It sure looks like the door and glass are two different pieces. It also looks like the glass wouldn’t clear the taillights if it swung in the same direction as the door.
That said, Doesn’t that thing that looks like a handle have to be a hinge cover? I can’t imagine that rear door is only supported by a single hinge. And the only logical answer to me is that the door and glass are one unit and that handle looking thing is covering up the hinge that helps support the whole assembly
OP
OP
Cysco
Here’s the first shot I’ve seen straight on from the back. We can see the door handle here.
Jeep Recon EV First Real Life Look! 2025 Jeep Recon Moab 4xe Concept Shown to Dealers at Stellantis Event 15E070EF-18B2-4B93-A847-2DD731E2BB54
OP
OP
Cysco
Here’s a better closeup of the rear handle area. It’s got finger prints on it so I assume that means it’s functional here. That section in the bottom corner is a weather seal/protector as it clears the taillight.
Definitely no obvious top hinges to allow the glass to go upwards like a wrangler. Maybe it’s a two stage right swing so you can swing just the bottom door or swing both the door and glass. This would support the idea that the rear glass is removable.
Jeep Recon EV First Real Life Look! 2025 Jeep Recon Moab 4xe Concept Shown to Dealers at Stellantis Event 7F9799D8-EEC8-4850-A54F-6AD471CEDF3D
Jeep Recon EV First Real Life Look! 2025 Jeep Recon Moab 4xe Concept Shown to Dealers at Stellantis Event 2025-Jeep-Recon-spied-3 copy
OP
OP
MaskedRacerX
I wonder what was going on with the interior? Maybe very prototype/placeholder at this stage so they didn’t want that circulating.
OP
OP
MaskedRacerX
RE: the rear door.
This kind of looks like how they solved that (if it does swing open from left-to-right), a hinge / pivot point that's further out than the light:
Jeep Recon EV First Real Life Look! 2025 Jeep Recon Moab 4xe Concept Shown to Dealers at Stellantis Event 1680012902900
There's a lot going on in that area, I need to load some pics into a photo editor and see if I can get some better contrast.
Not having to open the lower tail gate to open the top is one thing that we miss from some other SUVs we've owned (and like the R1S), lets you load up, open the top, and lean in vs. opening the lower gate and stuff coming flying out.
OP
OP
Cysco
I think you're spot on. Looking at all the pics and the video, there is definitely a bump out right there above the tail light. It's not a handle, but rather it extends outward so that the hinge can allow the window to swing and clear the tail lights. Very confident that's it.
Now the question is, does the entire back swing out as one or are the door and glass separate. Maybe there's an option for either. Having to swing out the door then swing out the glass would be a pain to do every time. It's one thing on just fling open the door and throw up the glass in a wrangler. Given the size of that door, it'd be a bit of an inconvenience to have to swing both open independently.
OP
OP
Fred
Hello
I bet $20 that it's 1 panel, because too heavy to have the tire on 1 hinge
OP
OP
dral97
There go my hopes of having that glass be able to retract into the tail gate à la 4 runner.
OP
OP
MaskedRacerX
That's an interesting point, maybe? Maybe the lower section is braced/hinged up higher too?
There's definitely something up with the rear window though, it's framed, it has that huge, funky hinge-like component to the right.
In the original release video, they made this whole point about the doors AND windows coming out, and they showed it with a missing rear window (this was before this new design iteration).
I hear you about the T4R window, we had a '07, V8, so nice for boards (of the SUP and surfing type :D) I lugged home an exhaust one time, so much easier with the rear window down.
Jeep Recon EV First Real Life Look! 2025 Jeep Recon Moab 4xe Concept Shown to Dealers at Stellantis Event 1680030500123
Plus it looked pretty sporty with the dual exhaust :D
OP
OP
MaskedRacerX
And green is EVERYWHERE. I noticed in the school pickup line the other day like 3 or 4 green vehicles.
Even Ford getting in on the green, and the whole "adventure" themed vehicle:
Jeep Recon EV First Real Life Look! 2025 Jeep Recon Moab 4xe Concept Shown to Dealers at Stellantis Event 1680197783944
OP
OP
COmtnbiker
@MaskedRacerX @Cysco @DougalsMD
Reviving an old thread. I believe the odds favor that the Recon will mimic the JL Wrangler with Sky one touch top.
I believe the side windows come out like the JL 4 door w/ one touch top.
The rear window appears to stay in place and the gate swings out, like the JL.
Also the rear glass bottom left corner has a plastic damper piece like the JL for a rear glass that lifts upwards.
To see a close resemblance, watch this video of a sales person removing windows of JL.
